Oliver 2-btm plow
fergienewbee
06-19-2008 14:41:33
Goiing to an auction Monday where they have an Oliver 2-btm plow for a 3-ph. Besides the shares, what should I look for? Is there just a single colter? Can I still get parts? Thanks.
Larry in Michigan
Leroy
06-19-2008 18:25:47
 Re: Oliver 2-btm plow in reply to fergienewbee, 06-19-2008 14:41:33
A coulter for each bottom, a 1 bottom would be just a single coulter, 2 bottom would need 2 and 3 bottom would need 3
Charlie M
06-19-2008 17:50:37
Shares are going to depend on the age of the plow. You can still get the bolt on shares at TSC as I bought one a couple of years ago for an Oliver plow. You can find coulters at junk yards or buy them new and other than tires and the other wear parts there isn't much else needed for parts on plows. If it used bolt on shares then you can probably buy the other wear parts new.
