Mark Susol
New User
has anyone ever replaced the roller on the NH 469? I have one I got last year that I was able to mow 20 acres with. the top roller is missing the rubber, and the guy before me let fence wire get into the bearing on the pto side so that bearing is now bad.
so i'm considering at least changing the bearing, is it as simple as 4 bolts, pull the sprocket and replace? the guard seems to be in the way of using a sprocket puller.
but has anyone actually replaced the top roller? it seems you have to take the machine apart a lot to get the roller out. newer models have this slot for the rollers to slide out.
also, the sprocket on the top roller is not well aligned with drive sprocket so the tensioner tends not to help keep the chain on. How exactly do i get the sprocket out to the edge of the bearing axle ? to align?
the top roller cost like $1100..most people say to get another used unit vs repairing. seems like this unit is in good condition minus the top roller.
