Broken Joystick Valve control Arm on Woods 1020 Loader
Charles Branch
06-01-2008 21:04:34
One of the valve control attachments on the joystick on my Woods 1020 loader broke. (See picture). Does anyone know what part I need and a source? The arm slides off of the main assembly. Can I replace just the broken arm and not the entire joystick assembly? Is this part the same on all the Woods loaders? The broken arm is non-magnetic, and looks like some sort of cast metal that I'm guessing is not readily weldable. The Woods WEB site has been inaccessible the last couple of days.
Craig Anderson
06-01-2008 22:55:42
 Re: Broken Joystick Valve control Arm on Woods 1020 Loader in reply to Charles Branch, 06-01-2008 21:04:34
I'm going to take a shot and GUESS it's white metal. If it feels heavy for its size it most likely is. If it's light for its size it's MOST likely aluminum and readily weldable.
An old time welding shop MAY have the rod to fix that for you if it is white metal.
