Trying to make repairs to a Gleaner A for small acreage work. I have both a corn and grain head. I now have a working straw spreader thanks to help on a previous thread.
Looking for advice on several other topics.
Brakes: anyone rebuilt these cylinders under the deck? Options?
Concaves: I've seen mention of "built up" concaves from an outfit in Indiana (?). How do I know if these are "built up"? New bolts suggest these were replaced not long ago. Leave them as is?
Flat, tooth plates under the corn head: name? should they be flat or bent up at the front? Two outside ones are bent, but also some teeth worn away from contact, so maybe are supposed to be flat?.
Bearing is shot in the unloading auger small universal joint. How do you get this out? Looks sealed, no spring clips in the ends, inner half welded to the inside of the tube by two struts. I need to remove it to fix the blades and replace the bearing.
Minor rust in the grain bin, was thinking of using Por-15, anyone use it?
