So i put the seal kit in my rear valves thursday and when i got all the hoses installed back on them and put the fluid back in i started the machine up and moved the levers, I'm sure i had this problem before cause it has been leaking the past 2 years i've had the machine. The 3 new o-rings between each valve section stopped those leaks there but I am still having a leak at the Flow Divider Valve, it starts dripping as soon as the engine is started, the fluid is coming down between the valve and the back plate, I am thinking the valve could have a crack in it? We looked at each one while it was off the machine and did not see a crack in any of them, should i buy another valve (good used one) and try it? The man helping me didn't think it could leak where the long 5/16 bolts go through.
