Harvest pictures, days gone by
Moline_guy
I came across a few pictures, I don't think I have posted before, a little bit of everything.
Thanks, always like seeing your case equipment, I always liked running those 30 series Case's. Use to be a handful of those white pull types in the neighborhood, now everything is corn and beans.
Dad ran two 96's in the 70's through the 90's, they were nice machines and reliable. A third was bought but we robbed it for parts. Both of my Grandparents ran 65's, great machine also.
36' rowse dump rake dad bought new in 87 or 88. Has a wheel on each end, one in back and two up front, never had an axle failure and it has bounced over a lot of badger holes. Great rake, just used it again
two years ago when the grass was short.
Neat countryside. Thanks for the great photos. South Dakota, if I remember right? If so, what part of SD? The flat land looks as flat as the Red River Valley in North Dakota and Minnesota.
The first pic, how do they keep the swather that wide run so far off center to track true behind the tractor?
In my clay soils the far side would sink in a bit at times, and you would be cutting at a 45 degree angle behind you I would think?
The 3pt mounted 10 foot disk mower wants to pull the tractor to the right in heavy grass.
I just cant see something that wide pulling straight!
Neat pics. Cool.
Paul
now this is what i like to view. machines with lil age still earning their place in the tractor stable
i like the lp jd pulling the hay crusher. used 1 on many acres sudan hay. sure speeds up stalk cure time so you can save the leaves
