need a fuel lift pump for a HE 217 john deere
Have a 1966 john deere 55 combine with a 217 engine and fuel pump is bad, any ideas where to get a replacement , thanks Joe 815-481-1411
(quoted from post at 08:42:08 11/24/22) Have a 1966 john deere 55 combine with a 217 engine and fuel pump is bad, any ideas where to get a replacement , thanks Joe 815-481-1411
Deere replacement pump is AT21275, nla.
Spencer Diesel, in Iowa, shows there's a replacement for it, CAV HFP914.
Call them @ (800) 658-3326 and find out if they are still available.
On mine I just added a cheap electric fuel pump. Some push, some pull. Push type need to be mounted below the fuel tank. Mine is on top of the elevator below the fuel tank. kelly
I should hasve added the electric fuel pumps to all 4 of the 45 combines I had. To get to running next season always had to pressureise the fuell tanks to get fuel up to carb to get to run. Big pain. $5's were gas engines but pumps are avaible for diesel.
Like others,I added an electric fuel pump. In fact,I even removed the non working manual and covered the hole with a piece of 1/8 steel plate.
