Gleaner F2 flashing amber warning lights
Farming north of Dallas. And people are always in a hurry.
I need to do something about amber warning flashers.
Was thinking about LEDs. Has anyone else done it? Said I might need a different relay to operate those. Dont even know if I have a relay now, though I assume I do, somewhere.
You need an electronic flasher unit that is capable of flashing reliably and at a steady rate at the low power draw of LED lamps.
Even then, the power draw of a couple of amber LED lamps may not be enough to make the flasher operate reliably.
There was a simple fix posted on the Farmall Forum back in 2019 that shows a fool-proof way to do this.
GOOGLE "10 Ohm 15 Watt Power resistor" for sources for the resistor.
