Yesterday while I was hauling and my son running the combine I noticed the Vittetoe chaff spreader was turning so slow that it wasn't throwing anything off. Fortunately we were doing corn so there wasn't much material build up. Seems like it would almost come to a stop and and then have a little energy to turn. I would assume it is either the little pump that also runs the reel or the orbit motor under the chaff spreader. Has anyone ever experienced this problem? I guess I could take the corn head off and pull up to the soybean platform and see if it will run the reel properly to test the pump. Amother thing I noticed is that the spreader seems to turn freely by hand. I thought orbit motors always had some resistance. Hydraulic tank is full and all of the other hydraulic systems operate that operate off of the big pump run fine. I did try adjusting the flow valve back by the spreader with no result. Thanks.
