We recently resurrected an old 703 power unit with a combine attached to it. We ve actually had pretty good luck with Combine, and have been learning how to set up and operate it. It is a good machine to handle weedy crops.
I just ran into a problem, that I am hoping someone can help me.
We had issues with the clutch master cylinder, that was causing it to shift pretty hard. I was able to replace clutch master cylinder and cure that issue. My problem now is, I cannot get it into reverse. I disconnected the linkage from the transmission, to make sure the linkage was not binding up, and it was free. It acts like it starts to go into reverse, but the gears will just grind. The shifter probably moves one forth the distance necessary to go into reverse.
if someone can enlighten me on what to look for, or suggest someone else that I can talk to I would appreciate it.
Thank you! Jim
Thank you! Jim
