Gleaner K2 Elevator Chain Question
nh8260
The clean grain elevator on my K2 is a little loose and needs to be tightened, how do you do that? The return elevator on the other side has a small handle that will tighten the chain but the clean grain side does not have one on it, the manual doesn't give much for instructions.
Thanks!!
There should be an adjustable slide on the top of the elevator at the top inside of the grain tank
Ben
Hey Ben, so i found the slide adjuster you were talking about, to tighten the chain i'm guessing you turn the nut so the slide comes up?? I did this but even with the nut all the way down the chain was still about as loose as before. Need to take a link out of the chain?
