Ih 1460 reel pump control valve-cant find a replacement
LotFotL
82 ih 1460. Serial 33,000. Electric over hydraulic. Ross reel
pump with electric motor. Toggle not dial reel speed
controls. The pin inside the valve body that is attached to
the pump, which the electric motor moves inward or
outward to control reel speed, has issues so im trying to
replace it, but cant seem to find the part anywhere. I can
replace pump, valve, and motor for $800, but that isnt
optimal, and my pump seems to be working fine. Called a
couple boneyards and they only have the other type of
pump without an electric control. Dont know how i would
swap out what i have for one of those but suspect not the
best idea. Anyone know where i may find this valve for sale?
My issue is a lack of reel speed ranges. The pin has been
modified in some ways and i suspect it now wont function
as it should have. I appreciate any leads. Thanks. Tim
What issues? With the motor or the modified pin? Does your parts book show the control unit broken down, to where the original shape of the pin can be seen? Is having a pin custom made an option, assuming that is the trouble?
Not to spend your money , just observing that given the prices of various hydraulic components today, much less labor costs, $ 800 for that unit at least appears to be in the ball park....but still a tough pill to swallow while trying to buy fuel.
