I have a question about installing the transmission screen.
I installed it with the open end with the collar towards the drain plug. I pushed the screen in, then put in the plug.
I wondered why there was a rubber wedge/gasket just inside the opening of the screen. It did not seem the screen would fit onto the shoulder of the plug.
Then when putting things away I noticed the parts diagram has the shoulder of the screen away from the plug (picture attached.) Perhaps the open end with the rubber insert goes in first?? doesn't make sense since the closed end would be towards the plug which has a tube/hole through it. A little confused
Thanks! Rich
Thanks! Rich
