Anyone looking for anything off a 700 combine? grain tank and header are missing. Going to cut it up when we get a warm spell, if anyone needs anything the parts themselves would be free, you pay the freight.
Located in Ontario, it doesn't cost a huge amount to send some of the smaller stuff a long ways.
Have a problem in the shaker system i have yet to figure out. Main thing is broke the outside shaker arm, found a used one and broke that one. Looked around for the problem after the first one broke and cant really identify the cause. Tried some things but the second one broke in a matter of 100 feet. Gave up and bought a nice 1660. I just hate to scrap out the 660, i enjoyed running it, auto header height cuts better then the 1660, plus has a hydraulic unload auger which seems rare. If i dont forget when it dries out outside ill crawl over it and maybe find what i might need.
my email is [email protected] if you want to hang on to that. If you dont mind me asking how many acres did you cut with the 660 in a year? I've got a few machines i have to drag out of the dirt this summer, and I doubt they are worth saving, but will have lots of good parts yet. I'd say you have a seized bearing or cracked frame rail. If you decide to let your 660 rest, I would be very interested in the hydraulic system for the unload auger if its the Case option, as well as the auto header height; IF its CASE.
At the time about 200 acres. The hydraulic unload auger is case, i had to put a sleeve in the lower auger as a repair. Previous owner also bent the face a bit hitting something at sometime in its life. The auger is also perforated style. Header is M&W Robot on 13 foot(?) header. It has been sitting for 3-4 years now so i need to make a decision. When its dry and not a mess out i will spend some time around it to make a decision.
Hello, I just seen your post about the Case700 combine. Is it still in one piece or have you already cut it up? I am looking for the straw walker cover to use as an awning over my shop door.
Let me know when you get a chance.
Thanks
just curious where are you at in Ontario?
