9500 combine
crowspond
recently purchased above combine i have very few metric tools. i would appreciate suggestions of common wrench sizes used on this particular combine . thanks in advance crowspond
Agreed.go buy a set or wrenches and a set of sockets.You're gonna need em eventually for any other newer purchace.If you can afford that combine,you can afford a hundred dollars for the tools to work on it.
Combine is being delivered this week 920 bean head. And 643 corn head I had couple of the mentioned wrenches. Wife wanted some Christmas suggestions looking on line for 6 pt socketsmore later crowspond
Menards had a close out on a set of 3/4 inch metric big sockets this summer, the same week I needed to remove the hitch bracket from my newish NH tractor, I was pleased to run into a sale on a name brand when I needed it!
Metric is odd in that it has lots of wrench sizes but several are not common and not included in sets. But you just know you will run into one when you need to keep running the most....
Paul
19 mm is the same as 3/4.12 and 14 are real close to 1/2and 9/16.18 is common,but nothing American is close..For anything above 19,I can usually find an American that will fit.As said,buy a set of wrenches and sockets and you will be set to work on about anythomg.
Found 6 pt socket set .separate toolbox for metric stuff got to remove aftermarket grain tank extension and let. Air out to get it in shop but that's tommrow
