Greetings,
I am fixing up our 975, and remembered that it has some sort of after market auto header height control. It has a bar under the header, with fingers on it, but there are no springs, and no control cables. There are 2 bolts on the right hand end of the header, that are connected to electrical wires. The rod that the fingers move, touches one bolt when it's up, and the other when it's down. There is no control box, only an on/off switch. There are solenoid valves installed in the header lift hydraulic lines.
I thought it must be an M&W Robot, but after reading others descriptions, it sounds like it is something else.
Anybody know which system this is?
Thanks!
Brian
Thanks!
Brian
