925 flex head
caterpillar guy
Having trouble with the middle of the knife bar not flexing like the rest. This is right in front of the feederhouse area. What is there to look at? We pulled the bottom skid plates and the stub that slid into the pocket /bracket on the bottom of the head. I can get pictures later today if that helps. There is a spot in the cutterbar where it dips down or back depending on the position of the head. The head is currently setting on the feed opening of the head. Cutterbar straight up.
I have the same some on a 925F head. Hope someone can answer it, my oler 920 does not do it.
45 I'm being told by the dealer that the flex arms underneath are bent. I am going to take one set in and have them look at them and compare them to new ones to see if so and how much. It really wears the poly out with it pushed to the ground to cut fairly close like it is.
