Cooling Fan Bearing Change JD 3300
LeakyBoot
Have an older 3300 with the fan only, no rotary screen set up. A lot of noise from the fan so took off the blade and belt and the hub turns fine but makes a rumble. I am guessing this hub was used on all the models from the early years of 3300, 4400 etc. Anyone know details of changing out the bearings? Are they a stock bearing or special JD only part? I have not removed the hub yet. Thought I would gather what info I could before I did that. Thanks, LB
It's a "waterpump style" 2-row bearing and it has to be pressed into the housing and the fan hub pressed onto the bearing's shaft.
Part # M75591, about $22 from DEERE.
(Similar to the bearing used at the disc on planter markers.)
