Ok, to start I saved a vert early Owatonna swather last fall from the scrap heap. Engine locked up, but complete. It has a Wisconsin 4 cylinder with all of the engine controls on the engine. I wanted to move the controls to the operating station, rather than on the engine. It seemed like a bad spot just in case something were to happen and you had to shut down the unit. So, I made a small 10? x 10? dash with a start button, choke cable, ammeter and on/off button. Last year, I was able to get the engine freed up and it ran great. Left it outside this winter, but I covered the engine with plastic and a tarp, fogged the engine and let it be. I went to start it in the old control configuration and no spark. Nothing. Nothing at the coil, plugs or points. So I figured now (2 days ago) would be a good time to install my new dash and controls. The new configuration requires a starter solenoid so I don?t have to run heavy cables 8 feet. I added the solenoid, wired it as I have on my Allis Chalmers D14 and Oliver 550, nothing. No click, no nothing. Moved it to a spot with a better ground, nope. Checked continuity to ground, good. Checked for 12volts at the battery post to the solenoid metal case, good. 12volts to the starter button, 12 volts to the S terminal when pushed. Nothing. Tried another new solenoid, same thing. What the hell? I can?t even go back and check for spark unless I can get this thing to crank. If I jumper the battery post of the solenoid to the stater post, it will crank. The whole purpose of the exercise was to eliminate long, large cables and to be able to start this thing from the safety of the seat. What am I missing?
