IH 234 Corn Picker 560 Mounts
Flash1pup
New User
We recently bought a IH 234 corn picker for our 560 International but the one belly mount that came with it is not for a 560 and the 560 mount we got from the owner was cut up for a 800 Case. We are not sure what the complete one is from. We tried to take our best educated guess to drill new holes to mount the sub frame but the mount is not in the right position. Our thought is if we could get some measurements from some factory IH 560 mounts we could either readjust and drill ours or fabricate a brand new set. Any help would be greatly appreciated, thanks.
Do you have the right axle mounts for a 560? If so bolt the axle mounts on. Put the subframe on the axle
mounts. Then jack up the front till the frame is level. Put your front subframe mount in place and see where
you need to drill holes to mount it. Does your sub frame have 2 cylinders on it or are using the Quick hitch
for lifting? I had the brackets laying around for a 560 to mount a 234 for years. Got tired of tripping over
them and they got scrapped about 2 years ago.
Gary
Thanks for the reply. We got it home a couple of weeks doing like you said, our first set of holes was high but we got it the second time, it does use the quick hitch arms for lifting. Overall it seems to be in pretty good shape, have to do some maintenance on it and maybe just a little tin work but we are excited to get it out working again.
