Gleaner K2 sheave?
TimWafer
Is there supposed to be a zerk fitting somewhere on the lower spring sheave on the transmission input shaft of the gleaner K2? If so where the heck is it located. I just got this combine and must be blind if there is one on it.
I finally found it this morning! Its tucked in between the sheave and what I believe is the end of the spring assembly. The position of the sheave puts it right on the bottom and almost impossible to see unless you are underneath with a good flashlight.
