1063 stalk roller spiral removal
mudcreek183
What is the easiest way to get the pins out and the spirals remove have several that need to be replaced this year.
I use grinder on one end and punch out. If not too loose I reuse and weld that end. A major problem I have is that spirals wear loose on shaft and cause bearing failure after second or third removal.
