Case rubber bushings supplier?
aussiecase
New User
I am trying to source rubber bushings to suit a Case 600 / 660 combine. ( 1960's model )
Part numbers are :
F 16808
and
505 BF2
I basically need a full set of rubbers.
The problem is that I live in Australia and need to find a supplier that can send internationally.
Any suggestions?
Thanks
(quoted from post at 14:13:33 12/20/18) I am trying to source rubber bushings to suit a Case 600 / 660 combine. ( 1960's model )
Part numbers are :
F 16808
and
505 BF2
Any suggestions?
Thanks
FWIW, it looks like the current part numbers are F16808 ($13.52US) and O4505BF2 ($16.96US).
Interesting that they are not available to you in Australia.
Hopefully, one or more of the "good guy" parts suppliers on here can help you, or you might try www.messicks.com and ask if they ship internationally.
Thanks Bob,
Yeah - seems ridiculous to have to buy from the U.S. but apparently it's the only way.
I'll try Messicks and also wait and see if I get any other replies. Price seems a bit high if that's per piece but I guess they are no longer a common part,
We have had no drama with getting stuff to
Australia from messicks. Brought in quite a
few newholland parts cheaper and quicker
than what our old newholland dealer could
do. Which bushes are they the shaker
bushes. We got some matched to suspension
bushs at pedders i think. We ran a 600 till
a couple yrs ago when the moter let go and
still use a 660 to harvest corn with 2 row
front if we dont need it for silage
Thanks d u f. I have tried Messicks and they can supply for a reasonable price but I'm trying to find a cheaper freight company. The one they use (fedex) want over $250 whereas I have ordered a variable speed drive belt from Jaydee and freight is only $72.
I hadn't thought of pedders - will give them a try on monday . Always a problem finding parts this time of year.
Surprised that you had problem with the motor on your 600. I have a few 600's and 660's and keep one running for harvesting grass seed but have never had any issues with engines - except maybe the old style governor.
John Saeli at external_link in NY can
get them for you. Getting them to you I
don't know about. He posts on and
watches the case board here, you can
contact him there too.
Not sure what happened to moter. Was a good well kept machine. Still hurts to see it sitting outside. Half way through barley harvest 4 or 5 yrs ago it pulled up half way down paddock blow the dipstick and oil filler cap out and dumped a heap of coolant sumwhere wasnt in the sump. Got it started in some sort of sick fashion and msnaged to unload it and lift front up then towed port old girl out of paddock and found a jd9600 to replace it. Been going to pull moter just for a look but never got there yet. Fell on another 600 the other day probably just be parts for the 660 if need be
