MaverickM23
Trying to find the right fuel pump for my IH 615. My combine works ok now but I feel that the pump is starting to fail and it is just a generic universal electric fuel pump, I?m not sure what the ratings are I would have to look at it tonight. When I bought the combine it had this on it and it has worked. I looked the numbers up online and found case part numbers 172110C91 and 175305C1 both of which are discontinued and do not list an alternative nor do they list any specifications. Do any of you guys know what pressure or volume pump I should be running with this combine? The reason I think it is failing is because it is getting hard to start and acts like it isn?t getting enough fuel and at times stumbles on acceleration. Thanks in advance.
