Fuel pump for IH 615 gas
Trying to find the right fuel pump for my IH 615. My combine works ok now but I feel that the pump is starting to fail and it is just a generic universal electric fuel pump, I?m not sure what the ratings are I would have to look at it tonight. When I bought the combine it had this on it and it has worked. I looked the numbers up online and found case part numbers 172110C91 and 175305C1 both of which are discontinued and do not list an alternative nor do they list any specifications. Do any of you guys know what pressure or volume pump I should be running with this combine? The reason I think it is failing is because it is getting hard to start and acts like it isn?t getting enough fuel and at times stumbles on acceleration. Thanks in advance.
For an exact replacement, GOOGLE "40106N".
"40106 Facet Cube Solid State Fuel Pump, 12 Volt, 4.0-7.0 PSI, 32 GPH "
What I am trying to find though is the rating or specs of the original pump, like GPH and psi. It does have to lift the fuel a long way up to the carb from the fuel tank.
Like Steve below I have many Case combines and have changed most over to electric pumps if they did not come with them, I have also installed them on my swathers, balers and CE units ect, I like to buy a 1-4 psi pump,, you go higher than 4 pi and many of those float systems will open and flow fuel past the seat and make the machine run too rich,, I have seen this 9 times out of ten, when I bought the higher psi pumps I had to then buy a adjustable regulator to give the correct psi the original pumps put out, I have four or four setup that way,, cost is double than just buying the lower psi max pumps out of the box, you will have plenty of flow .cnt
