John Deere 25 combine
I just found a JD model 25 pull type pto driven combine the other day. It looks to be in pretty good shape overall. I was just curious if anybody could tell me how much these way approx and what the spacing is between the wheels for hauling purposes. Also what do these generally sell for if theyve been sitting outside for years and not running. There are no canvases with it. Can these still be made?? Thanks for the help. Also what do you need for HP to run one of these? I have a JD 50 and was wondering if it would be big enough??
I'm guessing around 3500 lbs, give or take, in the past, folks posting here on YT paid from $50 $500 for one, but a good reference point would be scrap metal value in your area. Heard someone pulled one with their 60, but I don't know if they had PTO or engine model. As far as distance between wheels, can't you go and measure it? Would be the easiest to do.
Maybe others can chime in. Ralph.
A 25 or a 30 will fit on a 102 inch wide trailer barely. Like half a tire on both sides on the rub rails. So they are a bugger to haul. The 30 does come part pretty easy though. The 25 does not.
