Ok, so.. since the weather has been nice here in Michigan this week, I decided it would be a good time to once again try to get my picker going.
Got her to spark.. Carb cleaned up.. dump fuel into tank... and watch it pour onto the ground..
Hmm... appears there's a problem...
Pulled the fuel tank.. all rotted out where it sat on the cradle.. *shake shake* I hear a rattle... Roll the tank upside down.. WOW... about 7 million pinholes..
How did I not see all this upon previous inspection? I guess when I rolled it over, the rust took some of the bottom with it ..
Now that you've read my comic relief.. (was almost like watching the 3 stooges work on this thing today).. Is there anyone that knows where I might be able to find a tank? I'm sure I know someone who could doctor this one up, but I'd much rather have one that needs a little less repair.
But to finish out the day of wrenching.. Found a small plastic tank, zip tied it on.. "plumbed" it up.. poured gas in.. contact... *crank crank crank* Hmm... nothing.. *crank crank crank* nothing... adjust timing... *crank crank crank* BANG!! Fire!.. adjust timing... *crank crank crank* cough cough.. Little ether.. *crank crank* spit sputter... revs up a little.. stalls out.. Getting dark, time to call it a day..
I kinda feel silly giving the play by play.. but it was so good to hear it run.. even if only for 30 seconds or so, and I bet the first time it's ran on it's own in a lot of years. Still have a carb issue, as well as some other problems that I hope will somewhat correct once it runs a few.. (I know some rust and crud is on the valve seats in a cylinder or 2, likely causing what seems to be a weak draft through the carb)..
So, again, Needing a fuel tank for my treasure.. anyone got any ideas?
Thanks in advance,
Brad
Thanks in advance,
Brad
