The bearing on the shaft for the separator clutch and variable speed drive pulley is gone. literally...
I tried taking some camera phone pictures of it, but it's not working right for some reason. But, bascially, there is the outer race and the inner race, and that's it. There's nothing in the middle! That's about as bad as it gets.
I took the clutch off, and got the pulley off as well. I took the cover with the 4 bolts off, and the outer race came out. It's one of those self centering bearings. The inner race is going to be a challenge, since I don't want to remove the entire shaft from the machine.
Here's my thoughts:
#1 get out the mig welder, and run a bead around the outside of the race, and the heat should expand it enough to slide it off.
#2 use a die grinder with a honing die to cut through one side of th race, and chisel it off.
#3 weld some long all thread to each side of the race, and while it is still hot, use a plate with some nuts to draw the race off the shaft.
#4 torch it and risk marring the shaft, or blowing hot metal into the combien where it catches fire and burns it to the ground.
#5 drink a lot.
#6 build a clamp for my 8 lb slide hammer and give it some heat to knock it off.
I think #5 would follow #4 anyhow. So unless anyone else has any ideas. The shaft is too long for me to get any of my pullers on there.
Oh, and does anyone have a parts book for this machine? I'd like to know the number on that bearing.
Thanks again, Always helpful!
John
Here's my thoughts:
#5 drink a lot.
John
