MF 860 engine output shaft timken bearing
fdt860
06-03-2008 11:41:22
:) I need help to change the output shaft (special timken type) bearing in my MF860 combine.
I have removed the bearing and I have seen that it was installed the wrong way, when regarding workshop manual.
The thrust face should be toward threaded end of shaft (pulley end).
In my combine the bearing was mounted with the thrust face opposite to threaded end of shaft.
Should I install the bearing with the MF preconized way, or like it was when disassembled?
Help from a MF 750-760-850-860-865 owner is needed!
Thanks
