N-H TR70 Hydraulics
AllanC
09-10-2006 21:01:17
My new-to-me New Holland TR70 won't put the unloader auger out unless the engine is running at over half throttle, Variable speed won't respond at a low engine speed either. Table lifts great at all speeds, Do I have a hydraulic pump problem, need an oil & Filter change or what? Or do they " just do that"
Roger - Ks
09-15-2006 05:08:41
 Re: N-H TR70 Hydraulics in reply to AllanC, 09-10-2006 21:01:17
I have owned a TR 70 for 25 years. Some things - Unloading Auger, Reel Lift, are on a secondary Hydraulic system. The motor has to be at full speed to make them work. Look at the Hydraulic pump. There is a small pump bolted to a larger pump. It looks like one pump but is really two pumps. There is a drive shaft that goes all the way through the first pump. You need to pull the shaft out from time to time and check the drive coupler that connects the second pump to the first pump.
Kip2
09-13-2006 08:06:35
I have a TR70 also I bought it from the guys who bought it new that is the way a TR70 is set up it has to wide open
bluepaint
09-11-2006 18:46:28
I had a TR 95 , those hydraulics were fast even idling ( better than my 1688 IH)
Allanc
09-20-2006 20:25:18
 Re: N-H TR70 Hydraulics in reply to bluepaint, 09-11-2006 18:46:28
Thanks, I kinda suspected that, but it's nice to know for sure.
