Guys,
Didn't have muc luck on the tractor forum - would appreciate your help - if better place to post, pls advise.
Have a 6x4 Gator/gas, 97 model
Changed the oil/filter [Pennz 10W-30] 1.4Qtz w/ about 1oz of M-Mystery Oil. While letting her drain, I pulled the battery, cleaned and 12v trickled-charged.
Oil stick is reading pefectly in the center, but now the temp gauge light is coming on after running her for about 5-10 minutes. Fan has not kicked on...ambient temp here is from 35 - 59. I checked the radiator and [greenish] mixture is nicely coming to the top, resevoir is filled with a-freeze. Fins inside look perfect.
I have checked all the wiring to insure I did not disconnect something [fan-line, etc]. I remember reading something about a fan-sensor switch? Way to test this?
Anyway, I hope I can get this wrapped-up...thank in advance for any and all advice.
Thanks again,
tstex
Thanks again,
tstex
