Britcheflee
So, with advice from here I have the starter/gen reinstalled - connected up what wires I could and at first tried jumping it with remote battery - smoothly turned over the engine and it fired right up - I was not getting any charge from the smaller post at first until I increased rpm and now getting a good charge from it - showing positive charge at ammeter.
I am using a small 12 volt car battery - is this ok for this tractor? Or should I get a 12 volt garden tractor battery?
I was not able to get it to turn over by the switch - I think not only is the solenoid dead but the switch is corroded inside - the worst case scenario is that I put it all back together and use the battery with a jump wire to start it when I need - but I have a feeling that with new switch and solenoid I can get it to go.
Thanks,
Lee
Thanks,
Lee
