When I start the tractor and pull up on the PTO switch, it makes a loud noise and then tries to die. I dropped the deck and I can turn the pully with a finger on the deck and turn the blades.
I had the wife engage the PTO switch while I was under and it engages and turns freely. It makes the loud noise again when she disengages the switch. Does this point to the blasted clutch? I hope not as that is a little bit expensive.
Thanks again for all your help!
