I have a JD 214 with a 321 AQS Kohler engine. (original as far as I know) Been a great running machine. That was until my son left the key on for a couple days and I had to jump it with my truck. Dead as a doornail;; since, it wont run worth a crap unless I disconnect the 3 wire plug on the voltage regulator. It spits farts cuts out etc when connected; runs fine with it unhooked; I fear the stator may have shorted out from having to charge "full tilt" to recharge the battery; yeah I know about charging the battery with a charger rather than the stator but I needed the machine then and didn't have time to let it charge up 1st. It ran great for probably 15 min after the jump start, before acting bad. I disconnected that plug, finished my job, and then plugged the charger in. But even woth a now fully charged battery I still cannot plug that reg in and have it run right.
Being a battery ignition I didnt think the stator had anything to do with how the engine runs; had I had a magneto ignition that idea would definitely make a whole lot more sense to me.
