Hi,
I just purchased a Case 646 that has been repowered with an Onan CCKB.
The engine only runs on one cylinder. If you throttle it up to about 3000rpm the second cylinder will fire intermittantly.
I have done compression tests on both cylinders.
Both show about 110lbs.
I have swapped plugs and wires. No difference.
Any ideas where to go from here?
Thanks
Guy
Thanks
Guy
