Britcheflee
I have been given an old Lawn Chief walk behind mower with a B&S 5 hp engine. This is the high wheel version with engine located near the user and a belt drive (similar to that of a high wheel trimmer) to the large pulley at the front. I managed to get the engine running but need some help and information please. I was not able to find anything on the internet after an exhaustive search.
I need help with the following:
1. How do you replace belt?
2. How much oil (30wt) does this engine take?
3. There appears to be some kind of piston/spring under the front large pulley which is seized - anyone have any information on this and where to get new one? There is a braking system to stop front blade continuing to run and this is jammed on.
4. Second of the idler pulleys rusted solid - any source for getting new one?
Any pdf or other on line file for manual on this old mower. I think once I get it going it will be a beast so hoping to use it on rough pasture work.
Any information would be very useful.
Thank you,
Lee
Thank you,
Lee
