Chris Szilagyi
New User
Hello,
I have a John Deere 300 with the 16 HP Kohler K341AQS engine. It runs great until it has been running for over an hour (hot), it begins to have a bit of spark knock (similar to in a car when you get spark knock or ping) only when under a heavy load (cutting thick grass). Otherwise it never knocks and runs perfect even under a heavy load. It only seems to have this problem when it"s been running for an hour or so. I had the tractor in about 2 years ago and checked, and they tuned the engine. But, my question is, would this be something fixed by simply adjusting the mixture screws on the carb, or is this something with the points/timing?
Any advise is greatly appreciated!!! Thank you.
