I have a John Deere F935 with a Yanmar diesel. Last year, it began starting hard. After starting, it would run rough for a minute or so and then run normal. It would smoke cranking and when running rough, then clean out. After setting for the winter, it will not do anything. The glow plug light works, current with test light to all 3. The shut-off solenoid clicks and moves so I feel it is working. Engine turns over fast enough to start. A little light exhaust smoke. Battery is up normal. I checked the air filter, even trying with it off. I gave it a shot of WD-40 in the intake and it sputters a little but no start. Replaced fuel filter and got fuel to bleed at every connection so air is out.
The grass is growing now. I need help. Do I need to have the pump and injectors rebuilt?
Thanks
Thanks
