Hey gang,
I have a Kohler k241s that's been transplanted into a Speedex 1430. I didn't do the swap, and I'm trying to learn as I go. This motor doesn't charge the battery when it's running. It has a starter motor that turns the flywheel via a belt, but I'm wondering if this unit is a starter-generator. If so, how should it be wired to charge the battery? There is a regulator-looking box on the top of the starter with three terminals on it, but nothing attached to the terminals. There is one wire that leads from a post on the starter up into the regulator. There are no wires coming from underneath the flywheel.
Any help would be greatly appreciated!
Thanks!
-Parke1
Thanks!
-Parke1
