My old Briggs 14.5 i/c engine with damaged crank died last week. I ordered a new BRIGGS 17.5 hp replacement for it. This model superceded the older motor.
After engine swap was complete, fresh 30W oil had filled the dry crank case and all linkages were checked. Elcetrical connections double checked and power to pump and starter were confirmed.
ISSUE: After running for 2 minutes I shut off the engine and NOW it will not spark. There is fuel to the pump and the pump is energised. There is compression. And of course the engine spins but my timing light indicates NO spark on this factory new BRIGGS with less than 2 minutes on it.
This is a mystery!
Please advise... your thoughts would be greatly appreciated
Thanks
This is a mystery!
Thanks
