Need a camshaft for a Wisconsin engine
I have a complete S8D, good engine except for coil. I ran it on battery and automotive coil. I'll take $100.00. Down side is,---you know how heavy it is---shipping would make it not worth while. If you are in Central Texas might be worth while to pick it up.
L.D.
(quoted from post at 23:13:25 06/23/08) I have a complete S8D, good engine except for coil. I ran it on battery and automotive coil. I'll take $100.00. Down side is,---you know how heavy it is---shipping would make it not worth while. If you are in Central Texas might be worth while to pick it up.
L.D.
Would you consider tearing it apart and sending me the rod and piston,cam,lifters and head,I'll give you $100.00 for those parts,you can junk the rest.
Yes, but it may be a week or so before I can do that. Mine is S-8D3 Don't know if that makes any difference or not. Rest of #'s are 407050 586485, just to be sure the engine is the same. Note this came off the air shroud. You know it is possible it could have been changed. You didn't mention crankshaft. If you want it, I can send it along. Of course, with added weight, there goes shipping again. USPS has a flat rate box for, I think, around $8.95. Don't know how much I can get in their box.
L.D.
(quoted from post at 02:47:39 06/25/08) Yes, but it may be a week or so before I can do that. Mine is S-8D3 Don't know if that makes any difference or not. Rest of #'s are 407050 586485, just to be sure the engine is the same. Note this came off the air shroud. You know it is possible it could have been changed. You didn't mention crankshaft. If you want it, I can send it along. Of course, with added weight, there goes shipping again. USPS has a flat rate box for, I think, around $8.95. Don't know how much I can get in their box.
L.D.
My email address is [email protected],shoot me an email so I can get the details about sending the money and we'll go from there.The flat rate box was what I was thinking,if the crank fits too ok otherwise don't worry about it.
