I finally cleaned and found A MARK on the flywheel, a T with a dash. Is this the 20 deg. advance timing mark (or is it just the TDC mark) on a Kohler K301 or is there a S or and SP still hiding on there? It is all I can find after cleaning and sanding the flywheel throught the starter hole.
Also, where is the timing sight hole? I see a half-moon shaped hole (2"x1") with a circle beside it below the starter hole and a 1/2" hole on the carb/points side in the flywheel cover.
Thanks!
Thanks!
