Leaking crankcase vent tube
deene
I have a wheel horse model 800 with a Tecumseh engine i got running recently and it leaks some oil out of the vent tube around the area where it goes into the block. There is no blow by or smoking its just very loose, is there an o-ring that goes on this? Does it just snap out of the block for a replacement or are replacements available? thanks for any help on this, have a great day
.This motor is out of my 1966 Wheel Horse, has a 6 horse Tecumseh engine. The crankcase breather tube can be seen in some of these pictures kind of under the carb. the tube isn't in the block, it's in a little valve cover box in the block
partstree will definitely have this part, you just need to find it.
According to their reviews https://partstree.pissedconsumer.com/review.html they have the biggest choice of all the parts, which people can not find anywhere else. I think you can find there contacts of their customer service too, in case if you wanna talk to someone.
This post was edited by michakamp on 05/16/2023 at 12:39 pm.
