Kohler K301 12 HP
I only have one screw / bolt to hold the points cover on on this engine . Does anyone knoe the thread size and length og bolt ? Like for example 1/4 x 20 1 inch long max ? Can I get it at my local ( Ace ) hardware store ? Also , as I posted in my other post , does battery ignition mean it has points and condenser ? It does have those !
Thanks,
Whizkidkyus
(quoted from post at 21:54:59 11/05/22)
Thanks,
Whizkidkyus
Screws are 3/16''-24''X 3/8'' ''slotted pan head''.
#10-24 X 3/8'' is the same thing by another name.
''does battery ignition mean it has points and condenser''
Your tractor has ''battery ignition'' AKA ''Kettering ignition''.
Along with breaker points and condenser it also has a ''round can'' ignition coil mounted the the engine air shrouding.
Older Kohlers with ''magneto ignition'' also had breaker points and a condenser, but no external coil, the ignition coil on those is inside the flywheel.
I use phillips head screws, since I have a long phillips head screwdriver but I don't have a long Allen wrench that size.
