RB Green
New User
Where can I find rims for international cubcadet 1963 trying to fix it up for son it was his grandfather it was used hard number years he had 6 kids been in shed 10yrs I'm hoping I can still find a little life
Do a search for CUB CADET SPECIALTIES, they advertise on IH Cub Cadet.com, same guy owns them both, CC Specialties is THE LARGEST VOLUME CUB CADET PARTS SELLER in the USA. You call them and Charlie, the owner answers the phone. He has new and good used parts, and is very reasonably priced on everything.
Rear rims for the 6-12 tire were shared by Cub and many old lawn tractors of that same era. Simplicity Deere and Wheel Horse, for instance. Probably Bolens too. If you want OEM front wheels, Ebay has some from time to time. If they are not there this week, keep checking back.
One of my Cub Os came to me without front wheels. At an antique shop I found some drive wheels for a Troybilt Horse tiller. I put 7/8 I.D. bushings in them and now the Cub is on four good wheels. They look similar but not exact to the O.E.M. wheels on the other Original cubs.
P.S. If your rims are just rusty, get the grease off and see if somebody close has a bead blast cabinet and would clean them up for you.
It could be an Original with a v belt between engine and transmission.
Or a 70 or a 100 with shaft drive to transmission.
They all used the 6 x 12 rear rims and 4 x 8 front rims.
You can use wider rims if desired or are not needing the exact factory original rims.
The bolt pattern is 5 on 4.5 bolt circle.
Virtually any bolt on 12 inch rims from a lawn or garden tractor/mower have the 5 on 4.5 pattern.
You have to confirm if the back spacing will work on your tractor tho.
Some like JD had the valve stem on the inside towards tractor which is a hassle to me.
CL is also a good source for used rims.
I would start on Ebay - I have found lots of parts there for various cubs. Might take a while to comb through the ads as many people try to include as many key words on their items even if they are in no way
related.
ROLLAND - I did not know that! Every time I called him He'd offer to sell the business to me, but I didn't
want to work that hard. He built up a fantastic business!
I still visit the website a time or two a week. Not many of the old familiar guys post anymore.
DR. EVIL:
Charlie sold the website: www.ihcubcadet.com.
He still has and operates [b:5f7881390c]ccspecialties[/b:5f7881390c], which he sells Cub Cadet Parts.
