Company Logo (800) 853-2651 Shop Now
Troy Bilt 50
CKain(MI)
06-16-2022 10:08:52
I recently picked up a TroyBilt rider, has a 50 inch deck. When I turn it,. I can see the front wheels sliding some. Acts like a 'solid axle'. but is's not, at least each wheel spins freely when off the ground. Under power I don't know what a CVT rearend does in a tight turn??? Thanks
T.R.K.
06-16-2022 18:34:17
 Re: Troy Bilt 50 in reply to CKain(MI), 06-16-2022 10:08:52
It could be something binding in the transmission, but if it is the style TroyBilt I think it is, those had a lot of problems with the steering linkage wearing and getting the steering geometry off, which allowed the tires to skid. The bigger decks tended to wear out faster too, because they were heavier.
Do the front tires tend to get exaggerated toe in when backing up?
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? " ... [Read Article]
Latest Ad: WD45 Allis Chalmers tractor that needs some reassembly or will make a great donor tractor. I have the motor torn down currently and due to life changes, I need to sell. Tractor has Firestone 16.9x28 tires. Good metal,, carb, block, manifold, head, etc. Price is negotiable for cash. Calls only 7am to [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
