old Gravely mower clutch
caterpillar guy
Dad is looking for the clutch disc that goes into his Gravely mower. It makes the drive connection for forward and maybe reverse. I didn't get to look at it very much and he says the clutch disc is maybe bonded to one of the metal castings the squeeze it tight to move. I realize this is probably looking for a needle in a hay stack type of thing. Or where in the Mid MI area is there a place I could take it and they could put a new lining on the casting for it. It goes down inside the right wheel and is about 5-6 inches in diameter I would guess with out measuring. It is one of the original zero turns I would guess with the steering wheels behind it and drive with a roller chain from in front of you connected to the steering shaft mower deck is out in front of you. I don't know the model nor have pictures. Though I might be able to get some later.
Gravely # 12644 readily available online or Fleabay
Thanks Ray
Based on your picture it looks a bit different than the one you show. I did find some possibilities on there though some with a riveted lining on the casting and some linings to be riveted or bonded to the casting. Dad was into the local deere dealer and they gave him some papers with information about it also. Thanks again
