Well I am a Case guy!! Somehow I ended up with a 22hp(?) Toro 500,,,, supposedly has a Husky Trans now. My issue is when the
lever is put in Neutral, is does not stop moving. Usually just goes to reverse. Lifting foot off clutch doesn't stop it ! Some
back & forth on the lever, it may go to neutral... I tighened all linkage joints. appears to be from inside the rear unit ??
Any ideas ? Thanks
Any ideas ? Thanks
