Was visiting the neighbor, he was trying to get a Gravely 8123-G going.
It cranks but would not start. I determined it had no spark.
It was parked in a shed with no room to work around it (or even to get a good look).
I don't know the Kohler 301, but was fearing the points were buried under the fly
wheel. When I got home I looked it up.
Please confirm: Points are inside a box cover below the exhaust pipe at crankshaft level, left side?
So remove two screws and the box cover, file and clean the point and away it goes?
Also it has a fuel pump? Is that a mechanical pump, or a crankcase pressure pump?
And also the plastic gas tank has a fuel shutoff in the fwd right corner of the tank.
I didn't see that when I was there and how do you reach it? From front, outside of frame or inside?
If we pull it out so we can get to it that would be great. pushing it back in would be not so great.
The loader is up, and I don't know what is keeping it up, so danger!
I think he want to sell it. An 8123 with loader, what do they sell for?
Paint is pretty good. I forget if it has a mower deck. My memory oh no.
