John Deere 318 Manual
CaseChev
I am looking for an original mechanical repair manual for my 1992 John Deere 318 lawn tractor. I need to do some diagnosis on the electrical system and really need some help. I do not want a CD manual or some sketchy re-print if at all possible.
Thanks
Allan
262-844-1557
(quoted from post at 11:27:31 04/04/22) I am looking for an original mechanical repair manual for my 1992 John Deere 318 lawn tractor. I need to do some diagnosis on the electrical system and really need some help. I do not want a CD manual or some sketchy re-print if at all possible.
Thanks
Allan
262-844-1557
1992 would put it in the serial number range 11001- and would be covered by TM1590. There's several used originals on ebay starting at around $50, and you can buy new ones from DEERE, $117.10 by calling 1-800-522-7448.
Or a book that includes all 318's of all serial numbers and Models 322,332,420, TM2622, for $142.18.
If you care to post about the problems you are having there's some of us here who have been through them up, down, and sideways.
Thanks everyone for the advice. Right now I am chasing a problem with fuse blowing for front PTO clutch for mower. I wanted to have a wiring diagram to go thru circuit before I go ahead and replace the electric clutch. I would gladly accept advice from anyone who has been thru the same problem. Thanks
Try the troubleshooting procedure below.
Schematic, split on two pages.
https://i.imgur.com/5Ll7BJj.jpg
https://i.imgur.com/dW34jtF.jpg
Wore Out......thank you very very much. That is exactly the wiring diagram and diagnostic tree info that I was looking for.
Looks like you found what you needed.
I needed that very manual once. My small local Deere dealer would print off the pages of any manual and let me take them home. They closed and I went to the LARGE dealer. I was told it was THEIR information. I could look at their manual but was not allowed to print or take photos!
(quoted from post at 08:20:58 04/06/22) Wore Out......thank you very very much. That is exactly the wiring diagram and diagnostic tree info that I was looking for.
Please post back with what you find wrong!
